700r4 ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2003, 07:24 PM
700r4 ?
...a friend of mine put a 700r4 into an older pickup.. tranny works great except no 4th gear...he's played with the t.v. cable and such but nothing...any ideas?...is there something different that ingauges 4th that would be bad, beings how 1st thru 3 rd work fine.........thanks....
Old 06-21-2003, 07:29 PM
53vicky's Avatar
I think www.700r4.com has a trouble shooting area.
Old 06-21-2003, 10:50 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
A stuck valve body 3-4 shift valve.
A damaged 4th gear accumilator will blow off the pressure = no 4th gear.
If the other gears are shifting up & down then the governor circuit is working
