700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2010, 10:39 PM
700r4
Hi i have a 1992 silverado. With a 700r4 trans and i just had it rebuilt, it has less than 500 miles on it. And it has some problems. First it is making a howling noise in 1st and 2nd gear. Second it is slipping a little bit from 2nd gear to 3rd gear. If anyone has any suggestions please tell me.
Old 12-19-2010, 12:17 AM
call whoever rebuilt it and pitch a fit.. something is really wrong.
come to think of it.. my 700-r4 howls a little bit in 1st gear too...
Old 12-19-2010, 12:21 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Howl noise usually is bearing related. Torrington bearing between parts or pinion gear bearings in planet.
Slip or lag when shifting to 3rd can be a simple thing as TV cable out of adjustment. ALso an indicator of improper setup on the 3-4 clutch pack or small servo for 2nd gear
A few Questions on a 700R4 swap. zbhover Transmission - Rearend 2 02-24-2009 06:13 PM
700r4 conversion questions eric63chevy2 Transmission - Rearend 7 07-03-2007 02:37 PM
Putting a 1987 700R4 in my 1982 GMC 4x4... indy_85stariones Transmission - Rearend 12 04-28-2007 03:04 PM
700r4 and 4L60E hotrod66_57 Transmission - Rearend 5 09-14-2005 04:34 AM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 07:44 PM
