Do you still have the wishbone intact or have you replaced the front end?
Several vendors (Pete & Jakes for instance) have several options for mounting your Transmission. Almost all have something to do with splitting the bones or... replacing a section of the "X" member with a plate. I kept a stock type front end under mine. Used a Bell 4" dropped axle and split the bones with a Pete and Jakes kit. This worked out fine for me. If you have gone the Mustang II route then all you really need to do is blow the rivets out of the X member and replace the X member with a plate that ties the frame together and mounts your tranny. |
Check with Total Cost Involved. www.totalcostinvolved.com
Thank you guys. Both very helpful and the sites you recommended should be of immense help. I'll shoot some digital pix today and post, so I can pick your brains with a point of reference if you don't mind.
I have a 700r4 in my 40 ford. My frames X member was opened up so there was little problem.
There is a kit advertised in magazines that opens the X member enough to put a 700r4 in. I don't remember who made it. I think some of the trans tunnel had to be bumped out. Everyones floor I would guess is different. |
looked about 6 inches too long. Looking at it last night, I came to the conclusion that the x member had to be opened up, but my concern shifted to how to get the structural integrity back into the frame afterwards. I will also have to address moving the engine/tranny back for radiator clearance. I guess if I am cutting into the x member, I should use as much space as I can. The floor is all open at this point and a tunnell is non existent. |
Looks like all you need is a tranny mount on that little perch that the tailshaft of your trans is sitting on.
Not sure if this will help, but if you look at my Frame ('35-40 are the same), it has been engineered for a 700R4. It looks to me that maybe you will have to open up the Frame at the rear of the Transmission. Not suer if this link will work, but you can see it in my Journal-
http://hotrodders.com/journal_photos...1127273820.jpg |
Thank you both! Walt,I like the looks of your '40 (always wanted one)! Very nice!
| 1940 Ford pickup box and door questions? | Skiman | Hotrodding Basics | 10 | 04-04-2011 05:50 PM |
| My 35 ford coupe | gunnulf | General Rodding Tech | 7 | 11-03-2005 10:55 AM |
| ford 35 coupe | gunnulf | Hotrodding Basics | 2 | 09-19-2005 04:27 PM |
| Ford 302 into a 1940 Ford questions. | cyberbear | Engine | 2 | 07-20-2004 08:29 PM |
| putting a ford in my forty ford coupe | john kerr scotland | Engine | 6 | 08-07-2003 10:34 PM |
