700r4 1988 2-4 band burned only
Hi ya'll I am trying to figure out why my 700r4 works good 1,2,3, but when going to fourth gear it starts feeling like 3 and fourth are fighting each other. third time apart after rebuild only shows it burnt the 2-4 band everything else looks good. replaced band went through valve body with b and m instructions since it had been modified b4 I got the truck. My brother has rebuilt many 700r4s without ever having this problem. on the upside we are getting alot quicker at taking the tranny and transfer out. PLEASE any info would be appreciated.
I had a 4-wd truck once that burned the band after I went through it and I installed a shift kit. Think it was trans-go or B&m, not sure.
The problem I found after it burned the band out was the kick down bell crank hit the aluminum sleeve that the kick down spool rides in. It would not let the truck get a 2nd gear to low gear kick down a wide open throttle. After grinding so much off the aluminum sleeve it would work fine and cured the problem. The people that made the shift kit helped me figure it out. This was back in the 80's so I can't tell you exactly what I had to do but the aluminum sleeve was the culprit and it came from GM with that problem. Quote:
700r4 band it ?
Thanks for your quick reply. I will check this and let you know what we find out.Sure has been a hair puller.
IF just the band has burned up, besides the drum shape and condition;
I would want to know the size of 2nd gear servo, condition of the accumilator bore and piston for 2nd gear. Servo will usually have numbers on it to indicate the size. There are at least 4 different OEM size servo's from lite duty 4 and 6 cylinder to V8 to HD V8 application
At the Bonneville Salt Flats, first gear is known as 130 mph. |
700r4 burnd band
turned out to be forward clutch drum had a non visible crack
| Kevlar band & 700r4 low/revers in th350 | tomthecomic | Transmission - Rearend | 1 | 01-01-2008 08:15 AM |
| 1988 700r4 lockup question | Crazz | Transmission - Rearend | 4 | 04-10-2007 07:54 PM |
| 1988 camaro 700r4 | 81FIREBIRDESPRIT | Transmission - Rearend | 2 | 04-09-2005 11:02 PM |
| 700r4 band question | chevcamz28newbie | Transmission - Rearend | 0 | 08-05-2003 12:46 AM |
| 1988 700R4 | DADDYBLUE | Transmission - Rearend | 3 | 01-12-2003 02:40 PM |
