700r4 1st gear to short - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2009, 04:45 AM
American Muscle's Avatar
305 Turbo-Fire 240hp
I have a 700r4 in an 86 silverado and when i take off from a stand still i come out of first almost instantly regardless of how much throtle. i want first gear to hold a little longer. arent they suppose to hold longer? my gears are 3.08 12bolt
Old 12-01-2009, 05:39 AM
SSedan64's Avatar
You can try tightening the TV cable a click or 2. This will also extend other shifts. As would a Governor Recalibration Kit.
http://www.tciauto.com/Products/Inst...ble_adjust.htm
Old 12-01-2009, 06:21 AM
Is it shifting to second or is it acting like it goes right to high gear from first?
Old 12-01-2009, 06:04 PM
fast68's Avatar
likes chevy trucks & boobies
it should yeah
maybe the cable is stretched, wrong cable backet, or wrong geometry
is it all original?
my 91 700r4 in my s-10 holds first gear forever and ever when cold.
but its perfect when warmed up and runs drives awesome/
but its 197k miles so...
lol
Old 12-01-2009, 06:45 PM
it does shift into second quickly. whats the tv cable
Old 12-02-2009, 12:49 AM
SSedan64's Avatar
TV 101 >> http://www.tvmadeez.com/article/index.php
http://purplesagetradingpost.com/sum...o/700R4p1.html
Old 12-02-2009, 07:32 AM
302 Z28's Avatar
There is only so much in shift points that the TV cable can effect. You can change the governor to a Corvette one and that will move the 1-2 shift up to about 4500 rpm then buy tuning kit that has different weights and springs. TCI is but one firm that offers one.
Vince
th350, no 1st gear!! judis951 Transmission - Rearend 19 03-17-2007 08:41 PM
Internal Reaction (Ring) Gear shattered in 700R4... indy_85stariones Transmission - Rearend 8 11-30-2006 05:31 PM
700r4 governer gear problems chevcamz28newbie Transmission - Rearend 3 03-13-2006 07:26 PM
Ring gear size for 700R4 to 350 V8 in my 39 rwruther Transmission - Rearend 1 12-20-2005 10:08 AM
What ring gear works with 700R4 & 350? rwruther Transmission - Rearend 1 12-19-2005 08:41 PM
