700r4 2-3 and 3-4 shift problems. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2010, 10:19 AM
backyardboxwrench's Avatar
hello everyone, I need a lil help if anyone could offer a few solutions if possible ..it would be greatly appericiated.
Heres the deal: its a 700 r4 trans outta a 88 chev 1500 4x4.. when the truck was brought to me ..it had no 2nd or 4th gear , suggesting it was the 2/4 apply band .. i could force a 1-3 shift out of the trans at speed..but neutral if kicked down..or fast enough to allow a 3-4th shift..
Anyways..i yanked the trans..replaced the band..i didnt remove the valve body due to having to order a gasket set...so i just replaced the band. reinstalled the trans into truck...now i have shift issues.
i have set the t.v. cable / checked govenor /replace gov from donnor trans.
1-2 shifts great..2-3 shift needs to be forced..and 3-4 shift needs to be forced..once in 4th ..it downshifts firmly and strong throuout the gear selection.
up on stands truck driving in OD 1-2 shift nicely and firmly..2-3 shift ..needs high rpm and a quick couple pegs of the throttle will engage 3rd...and then ..same deal for the 3-4 shift..high rpm in 3rd quick couple pegs of throttle and it will grab 4th firmly .. trans isnt slipping in any gear.. fluid is clean and not burnt .. it "downshifts" firmly from 4th to 3rd ...3rd to 2nd ..2nd to 1st...
ive tried the idle in park and couple pulls of the tv cable to try and dislodge any trash possibly stuck in valve body..ive tried the same thing in all 4 gears..low rpm and quick coule tuggs of tv cable.
Still no easy upshift from 2-3 and 3-4 ..the shifts need to be forced.
Any suggestions short of yankin trans again would be greatly appericiated..thank-you.
Old 09-30-2010, 11:08 AM
randolphi's Avatar
What did the old band look like? (discolored metal? no lining? not that bad?)
Old 09-30-2010, 12:03 PM
not badlty burnt band
the band was burnt out for sure..didnt score the drum much at all...very little discoloration of band metal or drum..basically burnt the linning almost completely off the band. oh ya... and 1 ear was broken off the band where it locates into the case..where the servo apply piston is located. Hence the new band install...trans and lines got flushed ..twice now. and seems to be staying clear and clean ..not burning.
Old 09-30-2010, 12:26 PM
randolphi's Avatar
The filter probably kept the band material from going everywhere, I'm just a little concerned that the extra movement of the drum when, It (should have been held) by the band, has caused the clutch packs to be very overworked, and the seals in the clutches (internal pressure maintanace) might be too worn.
