Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 2/3 flash
Thread: 700r4 2/3 flash
Old 01-18-2012, 08:53 PM
tnsmith10's Avatar
tnsmith10 tnsmith10 is offline
when will it rain???
Originally Posted by onlyfnway
Ok heres my problem. I have 700r4 and the 1/2 shift is still good the 2/3 shift started to flash at high rpm shifts. took it to a local shop they pulled the pan no clutch fiber no metal shavings nothing. then pulled the valve body inspected it all, couldnt find anything. has anybody ran across this problem in the past. we have adjusted the dtent cable a 100 diff ways and it does not correct the issue. Any and all help is grately appreciated. Thanks
could be a few things offhand that i can think of...
1st, it could be that the checkball capsule in the case, could be in the 2-3 accumulator in the servo, 3-4 clutch apply piston has cut lip seal, or 3-4 clutches have too much clearance. or the 1-2, accumulator piston and pin are worn.
is this a new build or a high mileage trans?
the transgo jr kit addresses a 2-3 flare/cut loose shift as theyre known to have this problem.
