Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 2/3 flash
Thread: 700r4 2/3 flash
Old 01-19-2012, 06:43 AM
tnsmith10's Avatar
tnsmith10 tnsmith10 is offline
when will it rain???
Originally Posted by onlyfnway
The trans will go in to third, but when i shift at 6400rpm the rpms will flash to about 7100 rpm. the trans has about 1k on it. it also has the transgo 700-2-3 performance kit installed. thanks for the quick reply
in the 700 2-3 kit it has separate instructions for both type 1 and type 2 valve bodies, was the instructions followed properly for your valve body (not mixing up instructions between type 1 and type 2)?
also, are you sure that you set up the 2-3 accumulator in the servo with the right amount of washers?
other than that, id have to go dig out the instructions to my kit to see what else may have happened as i put 1 of these kits in my 72 ventura.
the thought of not getting pressure rise is not a bad thought, its just typical that if you have a flare, its going to be in more than 1 shift.
