700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2012, 06:38 AM
700r4
well its a must i have to rebuild my trans took the trans pan off looks like some water got in their and their was some good size metal in their to sucks. Im going to use a monster rebuild kit with vet parts in the kit and everything i need.
1. what can i use to cleam the parts i have to keep carb cleaner ?
2. is their some king of rags to use that wont put crap in my trans
3. is their upgrade spots to put the check balls 91 trans
4. while im in the trans what upgrades can i do with no cash
Old 01-26-2012, 07:24 AM
SSedan64's Avatar
1. Mineral Spirits, Carb Cleaner, both have a little Oil to prevent rust.
2. Compressed Air = no Lint.
3. CK Performance Shift Recal Kit.
4. Good ??
Old 01-26-2012, 03:18 PM
1,2, no problem 3 i was looking for a no cost like the older 700r4 their are some balls you can put in a new spot and some you dont even have to put in and 4 good ?? what is that
Old 01-27-2012, 05:23 PM
what about rubber gloves i hate them but if it will be better for being clean non latex no powder
Old 01-28-2012, 01:47 AM
SSedan64's Avatar
4. Good ?? = Good question.
The Nitrile gloves hold up well, http://www.harborfreight.com/catalog...sult?q=nitrile
Old 01-28-2012, 11:49 AM
ok got the gloves now what to do about the seals i would like to use the press on seals but i dont think they rent one at advance i dont have any other parts place i hope the kit comes with the split type
Old 01-28-2012, 01:55 PM
another thing to add is i would like to paint my trans i was told i have to use etching primer on alum but they dont make a high temp etching primer do i use etching thin high temp primer thin paint also what is the temp of a trans
Old 01-29-2012, 02:34 AM
SSedan64's Avatar
You can use some Mylar sheet or plastic from a bottle & hose clamps to resize the solid Teflon seals if it doesn't come with the Scarf/split seals.
Old 01-29-2012, 02:37 AM
SSedan64's Avatar
Shouldn't really need Hi-Temp paint, Trans normally runs about the same temp as the Engine coolant or slightly higher at times.
Old 01-31-2012, 03:12 PM
got my trans kit today its alittle more thin i was thinking their are alot of gaskets ALOT OF GASKETS i will try to post a pic of the parts
700r4 wahamilton87 Transmission - Rearend 2 06-08-2009 02:25 PM
need 700r4 help stoddern Transmission - Rearend 4 06-01-2009 08:26 PM
Removing a 2.8/700r4, Install V-8 with 700r4 1230firebird Transmission - Rearend 4 09-17-2007 06:17 PM
700r4 what to do? big b Transmission - Rearend 1 05-07-2007 09:53 PM
What are the parts in a 700R4 2-3 TransGo shift kit 700R4 2-3 AngliaBob Transmission - Rearend 3 04-24-2005 12:25 AM
