700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2013, 04:28 AM
700r4
I have a worn groove where my check balls go under the valve body. I am unsure if this will hurt the transmission or not. Looks like it should be smooth and insteadit has large gagged part sticking up.
Old 01-07-2013, 02:13 PM
rick 427's Avatar
Last journal entry: The Cheetah
What year trans is it??...And this worn groove, is it in a round hole in the seperator plate [where the checkball looks like it's trying to pop thru],or is it a grooved channel from 1 hole to another?
Old 01-07-2013, 03:01 PM
It is a 1989. The groove is on the webbing or channel of the transmission itself. Under the separator plate. Where the check ball goes there is a rounded out place and it looks like it slammed itself so hard inside the hole that aluminum is sticking up and the spot is enlarged.
Old 01-07-2013, 03:54 PM
rick 427's Avatar
You can take a large fine flat file and lightly go across the entire trans case where the valve body bolts on,and knock any high spots down.Don't focus on 1 area,go across the whole thing evenly....brake clean and blow dry when done...and the groove in the case webbing:as long as it doesn't go from 1 channel all the way thru to the 1 next to it,then it will be ok. If the seperator plate got beat up from the checkball,then it will have to be replaced.
700r4
Removing a 2.8/700r4, Install V-8 with 700r4 1230firebird Transmission - Rearend 4 09-17-2007 05:17 PM
700r4 silverbullet1967 Hotrodding Basics 2 08-24-2007 09:00 PM
700r4 C.sheppard Transmission - Rearend 0 10-19-2005 11:30 AM
What are the parts in a 700R4 2-3 TransGo shift kit 700R4 2-3 AngliaBob Transmission - Rearend 3 04-23-2005 11:25 PM
700r4 74huggerorange Transmission - Rearend 1 04-04-2003 06:05 AM
