700r4 3/4 accumulater - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2012, 11:46 PM
carl.p's Avatar
hi i am new here but could someone tell me is there a spring for the 3/4 accumulator in a 700r4 and a diagram of how it goes in ,just pulled mine apart to put a constant presser valve body in and there is no spring.. there is a spring in the 1/2 but not the 3/4.. gearbox is supposed to have been built in a professional shop thanks Carl
Old 05-28-2012, 01:25 PM
pricesgarages's Avatar
on the 3 -4 i use washer to brinng the piston flush for a more postive 3-4 shift on any 700 or 4l60e use the washers first then piston tabs facing down the dimples up check for wear at the pins as far as the 1-2 i keep the stock spring
Old 05-29-2012, 06:36 AM
Last journal entry: Still running strong
I didnt put a piston or a spring in the 3-4 acumulator.It was most likely built that way on purpose.
Old 05-29-2012, 07:33 AM
ive seen some people tap the feed hole and leave out but i stick with using the pison and washers
Old 05-29-2012, 11:45 AM
carl.p's Avatar
thanks for the reply guys
700r4 my oldcar Hotrodding Basics 3 02-19-2009 08:53 PM
700r4 I.D. 41'srfun Transmission - Rearend 5 01-24-2009 07:34 PM
Removing a 2.8/700r4, Install V-8 with 700r4 1230firebird Transmission - Rearend 4 09-17-2007 05:17 PM
What are the parts in a 700R4 2-3 TransGo shift kit 700R4 2-3 AngliaBob Transmission - Rearend 3 04-23-2005 11:25 PM
700r4 camarofreek Transmission - Rearend 2 10-10-2003 07:38 PM
