700R4 3/4 clutch stack? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2013, 12:53 PM
I am working on a 700 from an 89 GTA Trans Am. I removed the 3/4 pack and it has 7 steels and 6 clutches. The rebuild kit has 6 steels and 6 clutches. This is what I am used to seeing. Was there a stock configuration like this or was this something a previous builder may have done to cut down the clearance. I know I usually shoot for .060-.090". Seems like this would have been really tight.
Old 03-24-2013, 06:43 PM
I set up all of my 700s 3/4 clutch pack clearances at .040-.045 I have also seen as many as 9 and as few as 6 clutches Old school thinking was to add as many clutches as you could but the steels became too thin to properly dis ipate heat. Most new technology states to use kolene treated steels and a good quality friction and keep your clearances to the minimum side of the specs
Old 03-26-2013, 07:21 AM
pricesgarages's Avatar
i use a late 4l60 e kit with the thick steels i aways use new return springs i run them tight like .020 as long as u can turn the planetary gear in it its ok
T-350 Low/Reverse clutch stack, 4 or 5? jimsmonte80 Transmission - Rearend 6 09-28-2016 11:01 PM
700r4 3-4 clutch pack ASE Doc Transmission - Rearend 1 03-12-2013 06:05 PM
T-350 Intermediate clutch stack clearance jimsmonte80 Transmission - Rearend 30 03-09-2013 07:46 AM
How do you get the right height dimesions for the low and reverse clutch stack up old yukon Transmission - Rearend 12 04-24-2011 11:07 PM
700r4 clutch diagram chevcamz28newbie Transmission - Rearend 0 08-04-2003 09:11 PM
