700r4 3-4 wot shifts and freewheeling - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2012, 11:09 PM
I just installed a 383 sbc/ 700r4 in a lincoln town car. I rebuilt the 700r4 about 10 years ago finally used it and did some upgrades boost valve, servos, ect and I have a few questions. When the shifter in the OD position in freewheels in all the speeds except OD is the converter is locked. Is this normal? I think it is but it acts like a th350 with the kick down unhooked. I believe the TV is adjusted correct may be on the tight side. Also it will shift in to OD under WOT at about 4500rpm. If you hold it in drive it still will shift into OD under WOT. All other shift points are normal. Is all of this normal?
Thanks
700R4 will only shift out of 1st at WOT Burger Transmission - Rearend 5 12-31-2011 10:27 AM
700R4 won't shift @ WOT Typhoon Transmission - Rearend 6 05-18-2009 06:22 AM
700R4, only shifts @ WOT Hotwire Transmission - Rearend 13 09-05-2008 08:14 PM
700r4 shifts pink63impala Transmission - Rearend 7 03-16-2005 04:57 PM
700r4 won't shift at WOT Alex99 Transmission - Rearend 39 02-15-2005 09:08 PM
