700r4 with 3.73 or 4.10 rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2003, 08:10 AM
New Member
Question 700r4 with 3.73 or 4.10 rearend
If I put a 700r4 in my 67 chevy pickup(15 inch tires) what kind of rpm will I run at 65 or 70 mph
(freeway speeds)?
Old 02-25-2003, 02:43 PM
New Member
Post
I have a 66 chevy with 700r4 and 410 and at 60 I'm turning 2100 and 65 bout 2400. It works real good to me with a stong take off. If I was going to use it as a daily driver I would chose the 373 but If it is just a weekend cruser go with the 410. You will see the difference at the pump.
Old 02-25-2003, 03:15 PM
zonk's Avatar
Home Built Rods No Rules
Last journal entry: Home Made Sheetmetal bender plans
Post
est. with 27inch tire 3:73 @ 70mph 2275, 4:10@70mph 2500
Old 02-25-2003, 03:37 PM
New Member
Post
thanks for the info!
Old 02-25-2003, 05:18 PM
bg's Avatar
bg bg is offline
Post
Check this web site out, you put your own information in and it will tell you what your RPM and speed is.......
http://www.mtv411.com/auto/Gear-Tire...Calculator.htm
Bg
Old 02-25-2003, 07:00 PM
Mirror Image's Avatar
Post
I would go with the 373 its a better all around gear
