700r4 to 350 turbo. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2005, 08:57 PM
68novafan's Avatar
Ford Fan At Heart
700r4 to 350 turbo.
I have a 1989 chevy silverado (305) with (correct me if im wrong) a 700r4 transmission. The trassmission has been acting up lately (sluggish and slipping in and out of Over drive). I replaced the filter only to find a large amount of powder fine medal flakes in the pan. We are considering replacing the transmission all together considering it has almost 200k miles, with something beefier (we use the truck for heavy hauling use on our farm). From what I understand a 350 turbo should bolt up with lil work needed. Any suggestions on what kind of transmission I should use or how to put in a 350 turbo?
Thanx,
Old 03-19-2005, 09:04 AM
70chevyc10's Avatar
Having money helps
If your truck has a 700r4 now and you want to swap to a 350 there are two major differences youll have to address. One is the length of the transmission - the 350 is somewhat shorter than the 700r4 hence youll need a longer driveshaft, by 3.25". Second the tranny cross member will have to be moved forward I think about 6 inches. With some vehicles that might be a problem because of welded in cross members. The ony onther thing to consider is the overdrive, 700r4 has it - 350 doesnt. That may not matter considering your using it on the farm.
Old 03-19-2005, 11:52 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the t-350 was built in 5 different lengths.
3 different 2 wheel drive lengths ( 6 inch , 9 inch , 12 inch tail housings) and 2 4x4 shafts were used.
the 9 inch tail housing length on the t-350 will match the length of the 700r4 tranny in a 2 wheel drive application
Old 03-19-2005, 02:09 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Hey 68Nova.....I just happen to have a 700R4 that was rebuilt a few years ago. Drop me a PM if you are interested.
Kevin
Old 03-19-2005, 03:06 PM
Originally Posted by 68novafan
I have a 1989 chevy silverado (305) with (correct me if im wrong) a 700r4 transmission. The trassmission has been acting up lately (sluggish and slipping in and out of Over drive). I replaced the filter only to find a large amount of powder fine medal flakes in the pan. We are considering replacing the transmission all together considering it has 100k+ miles, with something beefier (we use the truck for heavy hauling use on our farm). From what I understand a 350 turbo should bolt up with lil work needed. Any suggestions on what kind of transmission I should use or how to put in a 350 turbo?
Thanx,
Personally I think you would be taking a big step backwards going to a th350. 700's can be build very beefy there really is no advantage in going to a turbo 350 but you will lose alot
Old 03-19-2005, 03:57 PM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
According to his post, he just wants the truck for hauling things around the farm. He would have no need for overdrive in this situation.
Get the long tailshaft TH-350 and bolt it in your truck if that is cost efficient to you.
Old 03-19-2005, 04:06 PM
68novafan's Avatar
Ford Fan At Heart
OK, I might as well stick with a 700r4 although the 350turbo conversion process doesn't sound to bad considering that the cross member is bolted on (I Removed it in aid of changing filter). The only problem I would see is that the drive shaft is one piece, changing to a 350turbo would make it rather long . Are there any other transmissions I might consider though?
Old 03-19-2005, 06:37 PM
68novafan's Avatar
Ford Fan At Heart
Will this still require me to move the cross member?
Old 03-20-2005, 09:50 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
If you change to a t-350 tranny from the 700 .... yes the crossmember will need to relocated a few inches.
This is a 2 wheel drive truck? 4x4 is a whole different story
Old 03-20-2005, 10:46 AM
68novafan's Avatar
Ford Fan At Heart
Sorry,, Yes its 2wd. also, Would the current trans. Be worth rebuilding, what are the metal flakes a sign of? Im a transmission Newby.
Old 03-20-2005, 12:54 PM
i took a 350/350 out of a mid 80's 2wd and dropped them into a 83 trans am that had a 305/700r4. i did have to get a longer driveshaft , but to my suprise , the trans bolted right in the same place on the cross member.i must have just got lucky with the right tailshaft length.
Old 03-20-2005, 10:50 PM
68novafan's Avatar
Ford Fan At Heart
I have what I believe to be a 200r4 transmission (got it out of a 88' caprice with a 4.3l, had overdrive), given thats its free I was wondering if it would hold up in the truck for a year or so as a bandaid (Till I get sum $$ for a better truck) if it where possible to put in, or if it would be cost effective to beef it up as a permanent fix, given its even possible to put in of course.
Old 03-25-2005, 09:07 PM
68novafan's Avatar
Ford Fan At Heart
any chance the toque coveter needing to be changed out with the transmission,,, i don't know much bout these things....thanx for the info thus far....
Old 03-25-2005, 09:52 PM
The T-350 mount is on the main case, not on the tailshaft housing. The 700R4 mount is about 2" farther to the rear than a T-350 mount. The 700R4 has the same overall length as a 9"-tail T-350, used from '73-'86 in 1/2-ton Chevy pickups (2WD). Your driveshaft should work fine with either one. Here's the TCI transmission dimensions chart:
http://tciauto.com/tech_info/trans_dims.htm
The 700R4 converter won't work on a T-350 without serious modification.
Old 03-26-2005, 07:52 PM
68novafan's Avatar
Ford Fan At Heart
anyone have any thoughts on the 200r4 or is it that stuped of a question, lol
Help with Turbo 350... Jason_R Transmission - Rearend 1 09-26-2003 08:12 PM
350 Turbo, Help Blazemore Transmission - Rearend 2 09-03-2003 07:24 AM
Turbo 350 1980 Malibu Transmission - Rearend 14 07-27-2003 05:24 PM
How much power can a turbo 350 take ratfink14 Transmission - Rearend 4 07-22-2003 10:45 PM
swapping a 700r4 with a turbo 350 on 4x4 chevy trucklover Transmission - Rearend 3 12-22-2002 07:39 PM
