700r4 3rd gear? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2003, 06:28 PM
New Member
Post 700r4 3rd gear?
I have been having a problem lately with when I'm running my truck it won't shift from 2nd to 3rd without having to let off the gas. I have a b&M snap shifter and I shift around 5500 rpm. when crusing it shifts fine. But when I drag, it won't shift out of 2nd without leting off the gas. I have heard other people with 700r4's with the same problem. What's the deal and what do you do to fix it.
Old 03-21-2003, 02:09 PM
Post
Does it feel like it starts to shift and then completes it after letting off the gas?
The 3-4 clutch is a very weak area of this trans and it will flare under load, I had the problem once. My trans shifted fine until I added about 100 hp to the engine and it had a bad 2-3 flare under power.
Old 03-23-2003, 04:28 PM
New Member
Post
What needs to be done to fix the problem. I have also tired moving the tv cable but that doesn't help.
Old 03-23-2003, 05:32 PM
Post
[quote]Originally posted by Mustang_Killa66:
<strong>What needs to be done to fix the problem. </strong><hr></blockquote>
Well you tell me...I asked you does it begin to shift and only finish the shift when you let the gas off...or does it not even attempt to shift until you let the gas off? There is a big difference there and no one can tell you how to fix that until you tell us what it's doing.
