700r4 4l60 servo help - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2012, 03:33 PM
Im putting my trans back together for the 5th time i keep forgetting parts im working on the servo i got the kit with the vette servo. I can not get the servo cover to go into its spot. The center part of the servo moves free but the part with the ribs wont turn and it will not move in and its holding the cover out any ideas.
Old 03-27-2012, 06:32 PM
its the 2nd apply piston will not go in far enough for the cover to go on. The rubber gasket and hard gasket wont go right the rubber get way big when fit and you cant push the hard split gasket together.
Old 03-27-2012, 08:47 PM
i found my problem their is not 2 seals on their one was in the wrong spot
bump delete this thread
700r4 servo question cecil07 Transmission - Rearend 1 06-01-2011 06:35 PM
700R4 adjustable servo south65ss Transmission - Rearend 3 05-16-2009 07:41 AM
700r4 Servo Install won't fit oldchevy1956 Transmission - Rearend 4 04-28-2008 02:43 PM
TH700 / 4L60 Servo pin seals C-10 Transmission - Rearend 1 04-24-2008 06:20 AM
Changing Servo on 700R4 KeithB123 Transmission - Rearend 4 01-26-2005 09:09 PM
