Originally Posted by jadejoky28
I have a 1995 GMC Sierrra K1500 that I need to rebuild the transmission on. It has an 4l60e transmission and a relative has an unused 700r4 rebuild kit. Can I use the 700r4 kit to rebuild the 4l60e.
Thanks
Jay
Some of it perhaps. The 700R4 came thru a long and painful gestation with many changes to the hard parts. Depending on what years the kit supports will answer what, if much, is usable. You've got to get to a 1992 4L60 version of the 700R4 before you get serious hard part compatibility with the 4L60E.
Keep in mind the 4L60E is electronically controlled, the 700R4 and 4L60 are not. The 4L60E's valve body is way different and has it's own problems vis-a-vis the 700R4/4L60. It also has a bunch of internal wiring that needs to be replaced with a rebuild, by the time you do the differences between 'em it will probably prove to be less expensive to just buy a 4L60E kit.
Bogie
