700R4 to 4L60E - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2008, 06:54 PM
DR132's Avatar
Sophisticated Minimalist
700R4 to 4L60E
greetings... I need to know if it is possible to replace a 4L60E with a 700R4, I know that mechanically they are the same tranny but is it possible to just install a 700R4 without hooking it up to the computer or will that screw things up? if not is it possible to hook the necessary wiring up to a 700R4 so it will be controlled by the computer or would I just be better off transposing the innards of the good 700R4 into the bad 4L60E? thank you!
Old 08-20-2008, 07:51 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the 700/4L60 trans can not repalce the 4l60E trans easily. The computer system receives feed back from the transmission 4L60E.... trouble codes will be set
The 700/4L60 can not be hooked to the computer to avoid trouble codes
Old 08-20-2008, 09:31 PM
DR132's Avatar
alright thanks, I kinda figured so but I thought I should know for certain...thank you!
4l60e to 700r4 static40 Transmission - Rearend 6 05-11-2008 09:37 PM
93 4l60e to 89 700r4 questions Bumper Thumper Transmission - Rearend 4 06-06-2007 02:07 PM
will 4l60e work in my 89 silverado? It has a 700r4. mojokimble Transmission - Rearend 2 04-21-2006 09:16 PM
4L60E and 700R4 similarities martinr Transmission - Rearend 7 12-18-2005 05:07 PM
700r4 and 4L60E hotrod66_57 Transmission - Rearend 5 09-14-2005 04:34 AM
