700r4 and 4l60e - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2009, 06:09 AM
700r4 and 4l60e
I have a 1995 GMC Sierrra K1500 that I need to rebuild the transmission on. It has an 4l60e transmission and a relative has an unused 700r4 rebuild kit. Can I use the 700r4 kit to rebuild the 4l60e.
Thanks
Jay
Old 04-01-2009, 01:56 PM
Thanks
Jay
Some of it perhaps. The 700R4 came thru a long and painful gestation with many changes to the hard parts. Depending on what years the kit supports will answer what, if much, is usable. You've got to get to a 1992 4L60 version of the 700R4 before you get serious hard part compatibility with the 4L60E.
Keep in mind the 4L60E is electronically controlled, the 700R4 and 4L60 are not. The 4L60E's valve body is way different and has it's own problems vis-a-vis the 700R4/4L60. It also has a bunch of internal wiring that needs to be replaced with a rebuild, by the time you do the differences between 'em it will probably prove to be less expensive to just buy a 4L60E kit.
Bogie
Old 04-01-2009, 06:53 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
you need to know what year this 700r4 kit is for.... the 4l60e trans and the later 700r4 use a different thickness frictions in the forward clutch packs.
be careful
Old 04-01-2009, 08:05 PM
Thanks for the information. I called a local transmission shop and he told me they were not compatable. I orded a rebuild kit for the 4l60e. The 700r4 kit was for a 1990 chevy 1500 and my vehicle is a 95 GMC Sierra 1500. Better safe than sorry I guess.
Jay
Old 04-01-2009, 08:18 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Jay
ok... the gaskets are not the same for a non electronic trans to a an electronic trans. best to buy the correct kit.
700R4 to 4L60E DR132 Transmission - Rearend 2 08-20-2008 08:31 PM
4l60e to 700r4 static40 Transmission - Rearend 6 05-11-2008 08:37 PM
93 4l60e to 89 700r4 questions Bumper Thumper Transmission - Rearend 4 06-06-2007 01:07 PM
4L60E and 700R4 similarities martinr Transmission - Rearend 7 12-18-2005 04:07 PM
700r4 and 4L60E hotrod66_57 Transmission - Rearend 5 09-14-2005 03:34 AM
