700r4 4l60e rear planetarys - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2010, 07:41 AM
what about rear planetary failure due to lube. What about the input to output oil seal worn out at 50,000 miles. i think maybe it could be the heavy overhung loads on the bearings. What do you think?
Old 10-31-2010, 07:56 AM
Sure it will fit
as far as the rear planetary goes, ive only seen them go when people get stuck and try rocking foward / reverse alot. id like to see a pic of it if you have one.
Old 10-31-2010, 10:38 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the loss of lube oil or reduced lube flow is often the cause of planetary gear failure.
There are causes for this loss of lube;
bushing wear, converter clutch material clogs cooler and lines.
Over heating the trans, tow too much weight in OD will wear the gears a bit faster.
Lack of proper maintenance. Fluid service at 30 - 35k miles is a good idea
another 700r4 and 4l60e trann ? backardracer Transmission - Rearend 6 06-28-2010 09:52 PM
4l60e to a 700r4 kickstandkraft Transmission - Rearend 1 04-29-2010 07:42 AM
700R4 with a 373 Rear Jsup Transmission - Rearend 6 02-27-2009 10:08 AM
700R4 and 4L60E Questions transmandan Transmission - Rearend 2 04-25-2006 10:24 PM
700r4 , 4l60 , 4l60e propaneburner Transmission - Rearend 2 01-10-2006 03:32 PM
