-   -   700R4 to 4L60E swapped already (http://www.hotrodders.com/forum/700r4-4l60e-swapped-already-217005.html)
chevyconfederate 03-20-2012 07:53 PM
i bought a 1998 Chevy Silverado half ton Z71 with a vortec 5.7. I just found out that the transmission in the truck right now is a 700R4. I need to know is what do i need to swap it back to the original 4L60E? Any and all help is appreciated. and i need it in a hurry its sitting in the shops parking lot right now and he will charge storage fees soon.
crussell85 03-20-2012 08:50 PM
Its sitting at a trans shop? Is the 700r4 bad? The gearing of the transmissions are the same the difference is in the valve bodies I think. You need to crawl under the truck and find out if the wiring for the original transmission is still there.
chevyconfederate 03-21-2012 01:12 AM
yea to both questions. I dony know ill crawl under it tomorrow when i go see the owner of the shop. only had PRN21.
chevyconfederate 03-22-2012 03:36 PM
Never mind the guy that looked at it was right but it was a electronic 700 so they just needed to bolt it up and connect it. But now i got to replace the intake gaskets. thank you for getting back to me so quickly though.
crussell85 03-22-2012 04:06 PM
A 4l60e is an electronic 700r4. Sounds like you need to find a new shop
chevyconfederate 03-22-2012 04:12 PM
i trust the owner not his workers though.
