700R4 to 4L60E swapped already - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2012, 06:53 PM
i bought a 1998 Chevy Silverado half ton Z71 with a vortec 5.7. I just found out that the transmission in the truck right now is a 700R4. I need to know is what do i need to swap it back to the original 4L60E? Any and all help is appreciated. and i need it in a hurry its sitting in the shops parking lot right now and he will charge storage fees soon.
Old 03-20-2012, 07:50 PM
The mobile view is crap
Its sitting at a trans shop? Is the 700r4 bad? The gearing of the transmissions are the same the difference is in the valve bodies I think. You need to crawl under the truck and find out if the wiring for the original transmission is still there.
Old 03-21-2012, 12:12 AM
yea to both questions. I dony know ill crawl under it tomorrow when i go see the owner of the shop. only had PRN21.
Old 03-22-2012, 02:36 PM
Never mind the guy that looked at it was right but it was a electronic 700 so they just needed to bolt it up and connect it. But now i got to replace the intake gaskets. thank you for getting back to me so quickly though.
Old 03-22-2012, 03:06 PM
A 4l60e is an electronic 700r4. Sounds like you need to find a new shop
Old 03-22-2012, 03:12 PM
i trust the owner not his workers though.
swapped engine, now 4l60e trans wont work. heavyfooted Transmission - Rearend 0 05-22-2010 05:32 PM
Swapped 700r4 now the engine is backfireing? Chevy350Sb Engine 25 12-09-2009 07:39 PM
4l60e to 700r4 razorshotglass Transmission - Rearend 4 09-24-2009 10:45 AM
700r4 and 4l60e jadejoky28 Transmission - Rearend 4 04-01-2009 08:18 PM
4l60e?? Th-700r4?? bambam36862 Transmission - Rearend 1 10-15-2003 03:26 AM
