700R4 to '58 283 flexplate and starter - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2009, 05:09 PM
About three years ago I acquired a 1958 283 sbc (complete). It came with the original cast iron powerglide. Now I want to use the 283 in a project. Attached to the engine is a factory adapter that allows you to bolt on the powerglide.
The powerglide has a smaller bolt pattern than the "newer" versions we are all used to. The adapter also has the mount for the starter. The original starter is held in place by three bolts, that run horizontal to the starter, not vertical to the starter like on the "new" engines.
In the area where you would mount a traditional starter are two holes that look like a starter could be mounted. I plan to run a 700R4 with this 283.
My question is: does anybody know what starter and flexplate will work on my 283 to allow me to use the 700R4.
Any help would be appreciated.
Old 01-09-2009, 05:26 PM
SSedan64's Avatar
This should help ID the holes that are present on your block & which flexplate to use.
http://www.chevytech.com/2c42o6.html
Old 01-09-2009, 05:38 PM
SSedan64,
Thank you for responding so quickly. Wow, this is a great forum for getting help. I never expected to get an answer so fast.
Again, thank you for responding so fast!
Old 01-10-2009, 10:07 PM
Hole "A" in my '59 283 block was drilled, but not threaded. I threaded it myself (3/8" x 16 tap size) and put it in a '69 Nova using the original 6-cylinder starter, flywheel, and bellhousing.
Old 01-11-2009, 11:18 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Your thread title has been edited. We're editing the subject line on threads to strengthen the search database, we know you're here with a 'question' and/or for 'help', stating that isn't necessary, being more specific in the title betters the chance of more hits in a search and more responses to your post.
See jmarks readme in the forum.
Semper Fi
Another Chevy Starter Issue (pic) Bluecollarron Engine 15 10-07-2013 11:12 PM
700R4 Torque Converter Flexplate Question fosterdl Transmission - Rearend 8 03-23-2008 12:03 PM
small blcok chevy! The ultimate starter problem! S.O.S. sugar ray Engine 11 07-19-2007 08:07 PM
Starter flexplate clearance Not A T 25 Transmission - Rearend 8 05-24-2006 12:27 PM
Starter gear to flexplate gap on SBC 32vicky General Rodding Tech 2 05-14-2003 05:39 PM
