700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2006, 06:11 AM
700r4
I am looking to put a 700R4 in our little nova and I wanted to know if anyone knows if a specific year of transmission is better than another? I will need to use one that has the mech speedometer.
Old 08-22-2006, 07:25 AM
The later ones are considered better than the early ones ...
It is very simple to change any of the 700R4's to a mechanical speedometer drive ... so do not let that influence your choice ...
Old 08-22-2006, 07:57 AM
I have a 700R4 in my 66 Nova and it's from a 92 Chevy. Mechanical speedo and column shifter both work well. You'll need to move the tranny crossmember 2" rearward or buy a pre-made one from places like Chevy2Only or BTO. The 700R4 is 3" longer than the original tranny so you'll need a 3" shorter driveshaft. One from a Vega will bolt right in using the stock rear u-joint or you can use a 2nd Gen Camaro shaft with an adapter joint in the rear.
Old 08-22-2006, 01:52 PM
700r4
Thanks onovakind67
Will I have to worry about any of the computer stuff? Or wiring?
Any recommendations on making it work better or stay together better would be welcome.
Thank you again
Lee
62 Nova Convertible
700R4 help/advice Mustangsaly Transmission - Rearend 7 12-12-2005 04:54 PM
700r4 and 4L60E hotrod66_57 Transmission - Rearend 5 09-14-2005 03:34 AM
700R4 with Vortec Computer Controlled Engine capps Transmission - Rearend 2 07-30-2005 02:17 PM
700r4 stock stall? Caesar_Mikey Transmission - Rearend 1 03-27-2005 05:52 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
