Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 03-25-2008, 07:29 AM
TpiRegal TpiRegal is offline
700R4 Accumulator and auxiliary valve body
Inside my late -87 tranny I have the forward clutch auxiliary valve body, and the 1-2 gear accumulator. These two have some scratches inside the cylinder/valve. Is it somebody that know what impact this damages may have for the tranny. Do I need to change them?
Thanks!!
Old 03-25-2008, 08:18 AM
Crosley's Avatar
Crosley Crosley is offline
Moderator guy
 Crosley's barnstar
re: 700R4 Accumulator and auxiliary valve body
the bores need to be smooth to avoid as many cross leaks as possible
Be kind to your children... some day they may be decide what nursing home to put you in
Old 03-25-2008, 05:54 PM
What happend with the functionality in the tranny, if I have a leak there?
Old 03-25-2008, 10:50 PM
Crosley's Avatar
Moderator guy
 Crosley's barnstar
as an example ; If the bore for the aux v-body accumulator is bad. The oil pressure for forward clutch is lost , this can result in slippage and a burned up fwd clutch pack.
Old 03-27-2008, 01:22 AM
Ok, thanks.
Then I will buy a new one. Maybe that has to do with slipping when kickdown with full throttle from 4 - 3. gear??
What about the 1-2 accumulator? What is the functionality for this one?
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
