Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 ATSG manual
Old 08-07-2006, 07:23 PM
Chazmac Chazmac is offline
If memory serves me right, they are talking about the 3rd accumulator feed hole (band release oil). This is a very good change to employ. Use the gasket as a template to make the hole. The gasket will be teardrop shaped at that location. Make the hole at the small end of the teardrop shaped hole in the gasket. If your plate has the hole you can enlarge it.
