700R4 ATSG manual - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2006, 05:43 PM
700R4 ATSG manual
I have a 700R4 ATSG manual in it(page 77) states that you should drill hole 44 in the spacer plate out to .093 even if the hole is not present. But they make no mention on this hole in the gasket pages or the VB passages. Has anyone dilled this hole(to help 3-4 shifts-clutches)? I tried calling them, they want $25 to talk to me about it.
Old 08-07-2006, 07:23 PM
If memory serves me right, they are talking about the 3rd accumulator feed hole (band release oil). This is a very good change to employ. Use the gasket as a template to make the hole. The gasket will be teardrop shaped at that location. Make the hole at the small end of the teardrop shaped hole in the gasket. If your plate has the hole you can enlarge it.
Old 08-07-2006, 07:25 PM
PS
That will be $20.00 What a bargain....
Credit cards accepted
700R4 – Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 12:49 PM
TH350 Manual Valve Question Pantload Transmission - Rearend 6 02-19-2006 01:48 PM
700R4 Manual valve body shifting problem thez84 Transmission - Rearend 1 11-22-2005 08:00 PM
700R4- full manual control powderbill Transmission - Rearend 4 02-11-2005 09:03 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
