700r4 B&M shift kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2007, 11:02 AM
olred's Avatar
700r4 B&M shift kit
Has anyone had experience with this kit?
I installed one in an 89 700r4 and now 2nd gear slips like mad. All other gears and function work fine. line pressures are all below 200#. Trans was working fine before but was just alitlle soft on the shifts.
Old 03-24-2007, 11:38 AM
That kit works fine. Most valve body kits do the same job.
I suspect that there are installation issues. Is the pressure regulator snap ring in the correct groove? Any check balls missing? Are the separator plate gaskets in the correct location and matched to the plate?
Old 03-24-2007, 08:30 PM
olred's Avatar
Thanks for the reply. I had to replace the seperator plate with a Transgo universal plate and the b&m gaskets. They lined up ok but I noticed holes in one would be square while coresponding holes in the other would be round . Wondering if one slipped.
Also is there more than one groove for the slipring in the pressurevalve bore? I noticed a ridge and then a groove but the pliers I have wouldnt reach any deeper.
4L60E Shift kit. GMCTRUCKS Transmission - Rearend 8 05-20-2012 03:22 PM
need AOD shift kit advice murrsue Transmission - Rearend 5 09-16-2005 09:04 PM
1984 700R4 B&M Shift kit question Russell52 Transmission - Rearend 4 02-25-2004 09:45 PM
my tranny wont shift hard even with shift kit notmrgoodwrench Transmission - Rearend 4 08-12-2003 06:10 PM
B&M shift kit insallation jmi Transmission - Rearend 5 04-09-2002 11:13 PM
