700R4 B&M speed sensor - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2009, 10:44 AM
I am considering switching transmissions from a TH350C to a 700R4. Presently my TH350C lockup feature is activated with a B&M unit (70244) which senses the mph and will activate the Lockup at any specific dialed MPH. It works great. B&M literature says that the same unit can be used on a 700R4 but to "Deactivate the converter clutch shift valve by removing the spring holding the valve train in the OFF position". All of these instructions can be seen on their website. Was just wondering if anyone here has used this B&M lockup unit on their 700R4 and, if so, was there any problems incountered or additional modification to be done.
Old 01-21-2009, 11:17 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
That mod shown is if your new trans achieves lockup from the valve body. If lockup is achieved through a solenoid, (as before with your TH350C) then your present switch will work.
"Dollars are like votes, except that they actually count."
TPI / speed sensor mobileortho Electrical 5 08-07-2008 10:49 AM
Mech speedo/Vehicle speed sensor?? warren1328 Electrical 1 06-19-2006 12:57 AM
Vehicle Speed Sensor 88chevy Electrical 4 06-17-2006 05:20 AM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 03:36 PM
electrical speed sensor Tom Welshans Transmission - Rearend 2 11-11-2002 07:58 PM
