700r4 backup switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2006, 08:05 AM
700r4 backup switch
Purchased this Lokar backup switch for hooking up reverse lights. Has anyone ever hooked one of these up. I think i get how it works that it depresses the small ball when car put into reverse. But not sure exactly where to mount and what to hook to the two terminals. If anyone could step me through it I would be most appreciative.
thanks
kevin
Old 09-18-2006, 10:04 AM
Jmark's Avatar
What kind of car is it going on? Floor shift auto or column auto? Most cars have the backup switch built in to the ign switch down on the steering column.
Lokar makes different ones, which one do you have?
Here is some info on them.
http://www.lokar.com/interior_pages/questions.htm
They have a mechanicl switch that mounts to the trans pan rail on 2 bolts. Looks like the shift lever on the trans pushes on the switch to get the reverse lights. Then you will have to wire it too.
http://www.flamingriver.com/index.cf...121/prd121.htm
Mark
Old 09-18-2006, 10:28 AM
hi
going in a 50 mercury. all new wiring & column shift. SO nowhere I can see is option for reverse lights.
i was not sure exactly where to mount the switch i have and how to wire the 2 terminals. I have the kit you show in your link.... just want to make sure I install it correctly.
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Starter switch stock to modified wiring question. Kallie49 Electrical 5 06-23-2006 06:01 PM
toggle switch on 700r4 Danscam Transmission - Rearend 3 06-21-2006 04:13 AM
backup light switch location 19nova72 Transmission - Rearend 2 07-11-2005 08:23 PM
Backup Lights Switch Question horvath Electrical 5 03-05-2005 06:47 PM
