700R4 Behind a BBC? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2012, 07:45 PM
11echo's Avatar
Old Guys Rule!...EVERYTHING!
700R4 Behind a BBC?
I was planning to put a 700R4 behind a 454 (street engine), primarily for the 4th gear and mech. speedometer. But in another forum, they are saying the 700R4 can't handle the BBC torque? I've never dealt with a 700R4 before, so I don't know. Anybody can confirm or deny this issue?
Old 03-20-2012, 09:10 PM
BOBCRMAN@aol.com's Avatar
A stock 700R won't last long. Unless you drive with an egg on the loud pedal.. Too much torque for a stock trans with any kind of "spirited" driving.
Old 03-20-2012, 09:21 PM
I ran a 700r4 behind a 468 for about 2 years never had any problems with it.
Old 03-20-2012, 10:34 PM
Prof. T. Soggmeyer's Avatar
Plan B
You can one get built to take that power though I would not put a stock one in.
Old 03-20-2012, 11:22 PM
BBC with 700r
What would be a good tranny to bolt to a 454, as i plan to put a 454 in my 88 Chevy 4x4 this year, i hate the 700r tranny, i have put 4 of them in, in the last 5 years, 1 rebuild and 3 from the junk yard. And it cost a lot to have them rebuilt.
Thank You....
Old 03-21-2012, 07:00 AM
35WINDOW's Avatar
Last journal entry: Dash Mock-up
I am a big fan of a 4L80E, and in stock form can handle upwards of 650-700 h.p. (I'm using one in my build)-it is basically a 400 with an overdrive. The downside is that it has to have a "Controller" (Computer) to operate. If you can live without the overdrive, a TH400 is a Tank-
If you decide to go with a 4L80E, there are a bunch of stand alone Computers out there (and it seem like more of them are available each day). I like the Optishift personally, although there are many, many more-
Here is the Optishift (bottom of the page):
http://www.jakesperformance.com/images/optishift.jpg
Here's the Compushift (bottom fo the page)-
http://www.transmissioncenter.net/4l...FQ1U7AodYTzEwg
Old 03-21-2012, 07:27 AM
BBC bolted to 700r
Thank you 35Window, you was a great help, and i will be bolting one of those trannys to the 454, when i drop it in this year....
Old 03-21-2012, 08:38 AM
35WINDOW's Avatar
If you choose to use a 4L80E (and it had a TH350 in it before) you will have to modify the Trans Crossmember and shorten the Driveshaft-
Old 03-21-2012, 09:20 AM
700r behind a BBC
Thank you 35window, it already has a 700r in it, it is a 1988 Chevy 4x4, 2500,extended cab long bed. It came with a 350 motor and 700r trany, i got a 454 out of a 1990 1 ton to put in it this year, the 350 that is in it now is gutless. The 454 should give it the power i need. I have had nothing but bad luck with the 700r trany's.
Thank you...
Old 03-21-2012, 11:12 AM
SSedan64's Avatar
If you don't mind Manually shifting you can use the 4L80E without a Controller. It's a little cheaper anyway.
http://transgoonline.com/products.ph...dcountview=Yes
http://www.summitracing.com/parts/TRG-4L80E-3/
Plug & Play Unit, Rossler's "Little Black Box" @bottom of Pg.
http://www.rosslertrans.com/
Old 03-21-2012, 12:57 PM
7oor behind a BBC
Thank you for the suggestion, SSedan64, cheap is always better for me, lol, trying to raise my two daughters on a shoe string as it is. But it would be kinda of a pain, this will be my main work truck. I cut and haul fire wood and scrap metal and cars too. Thats the reasoning for the 454 instead of the gutless 350 it has in it now. And a good trany that can handle big loads in the woods or pulling cars on the freeway.
Thank You...
Old 03-23-2012, 01:12 PM
1991BBC454
454 infront of a 4l80e
ok if you are not going to work the tranny that hard i would go with the 4l80e. But if you are going to work it to death there is no way i would buy that tranny. I have a 1991 1 ton with a throttle bodied 454 putting out around 440hp with a 4l80e backing it. I work the crap out of this truck and i am on my 6th 4l80e tranny in 140,000 miles. I am pulling loads of more than 17,000 pounds with it though. It would be a great tranny if it were just for a cruiser or hot rod but definatly not for a truck that you want to be able to beat into the ground and not have to worry about breaking on you. Good luck!!
Old 03-26-2012, 10:08 AM
700r Behind a BBC
Thank you 1991BBC454, this is why i am looking for a good strong tranny,the 700r cant take the work load, i will be running a stock 454, in my 1988 Chevy 4x4, extended cab, long bed, 3/4. It has a gutless 350 in it now, i cut and haul fire wood for a living, so i need a strong tranny, that will handle big loads of wood. Nothing makes a person sicker, than being down in a hole and try to pull out, and you cant, ether because the tranny wont hang with it or the motor powers out,then you have to throw half your load off.I also haul scrap and tow cars with this truck, so it has to have some kind of over drive too, by far, this is no hot rod or trick truck, just my work horse. It wont pull as much as yours 1991BBC454, but it will be close...
Thank You.....
Old 03-28-2012, 09:35 AM
SSedan64's Avatar
With that kind of load '1991BBC454' you need a Diesel with an Allison Trans.
Not many OD Trans are capable of Hauling heavy loads In OD gear. Most recommend using D, including the 700R4/4L60/60E/65E/70E. I'd only use the 4L80Es' OD on flat level road when towing something really heavy.
As for pulling out of a hole, taking off, the 700R4/4L60s' low 3.06 1st gear would be better than the 4L80Es' 2.48 1st gear.
700r4 I.D. 41'srfun Transmission - Rearend 5 01-24-2009 07:34 PM
Bto 700r4? XNTRCI-T Transmission - Rearend 5 12-16-2008 09:12 PM
Removing a 2.8/700r4, Install V-8 with 700r4 1230firebird Transmission - Rearend 4 09-17-2007 05:17 PM
what is this on my 700r4 MRGM Transmission - Rearend 7 07-14-2007 05:59 PM
What are the parts in a 700R4 2-3 TransGo shift kit 700R4 2-3 AngliaBob Transmission - Rearend 3 04-23-2005 11:25 PM
