700r4 behind a big block ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2011, 02:38 PM
What are the limits for TH-700R4 trans power vise ?
It's newly rebuilt with shift kit and it's got more clutches in 3/4 gear clutch set (9 if i remember correctly)
I am thinking about putting BBC 396 into my Jeep CJ7, 4000 lbs.
Honestly I would say that in the set-up I would have that engine in it should make somewhere around 400/425 hp and 450/475 Ft-lbs of torque !
The Jeep has a mildly built 350 SBC now and the transmission seems to handle that fine. Im running a stock converter from V6 4.3 S10 Blazer. The Jeep is on 38" tires and is it's mostly going to be a toy to use in the winter, driving in snow !
Old 09-21-2011, 03:16 PM
lt1silverhawk's Avatar
"But how do it know?"
Last wiki edit: How to rebuild a Rochester Quadrajet 4MV carbureto... Last photo:
Wiki Edits: 132
Hey Icejeep,
Based on some research I did some time ago (dropping a big block and a supporting transmission into a Camaro for low-buck racing fun), I understand that a properly built TH-400 is the ideal transmission to have behind a big block.
Hopefully the more knowledgeable members will soon chime in with good info.
700r4 big block g&s restorod Transmission - Rearend 7 11-20-2011 08:17 PM
1988 700r4 against 70 350 block gyrocopter1 Engine 5 09-19-2011 08:08 AM
4L6OE to a 700r4 V6 block dartgt4speed Transmission - Rearend 8 10-25-2009 08:52 AM
500ish HP Big Block w/700r4. Anybody running one? dough88 Transmission - Rearend 12 05-21-2007 09:03 PM
Will A 55' block 350 bolt up to a 87 and newer 700r4 j_sirnio Hotrodding Basics 3 01-29-2007 08:52 AM
