700R4 bellhousing bolt pattern question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2011, 01:53 PM
Moose2's Avatar
Moose2
I found a 700R4 transmission for sale on Craigslist and the seller says it is from a half-ton 2-wheel drive pickup with a six cylinder engine. He got the tranny long after it was removed from the truck so he tells me he doesn't know what year the truck was. Can someone tell me if the bellhousing bolt pattern on this 700R4 will mate to my late seventies 350 (Chev)???
Old 01-24-2011, 01:59 PM
The 700R4 came with one of two bellhousings, the standard Chevy bolt pattern and the narrow GM Metric pattern first used on the 60 degree V6 motors. If yours came from a full size truck, it's certainly the Chevy pattern. If it came from an S-10, it could be either, since the 2.8 used the small pattern and the 4.3 used the Chevy pattern. Should be pretty easy to tell just by looking at the bellhousing - the Chevy pattern has a point at the top.
1936 chevy bellhousing bolt pattern powerrodsmike Transmission - Rearend 3 11-15-2008 06:27 PM
Need dimensions for a BOP bellhousing bolt pattern Arrowhead Engine 2 10-25-2007 11:53 AM
Bellhousing bolt pattern LS1 vs gen1 70bird Engine 1 12-12-2006 11:24 PM
Bellhousing bolt pattern dutch paul Transmission - Rearend 9 08-20-2005 03:38 AM
bellhousing bolt pattern crshrmn3 Transmission - Rearend 2 02-04-2003 05:05 PM
