700r4 big block - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2009, 02:02 AM
Ifit aint fix...Don't broke it
Last journal entry: 52 fleetline firewall
700r4 big block
I got a pile of 700r4s laying around but every time i try to build one and stick it behind a 4-500 horse big block it ends up grenading . 350s and 400s are becoming scarce and I am starting to geeze so the muncie option is quickly going away. I have tried some other stuff but it all is really expensive. anyone got some neat tricks to make a 700r4 stout enough for 500hp and tubbed rear? I have had 3 different EXPERT xmission guys assure me that they could do it and all i have to show are 3 piles of aluminum . I would like to know kit PN# and specific details as I will do this myself. I have done many pglides and 350-400 rebuilds so I am not a total idiot. I just do not do it enough to be really up to date. thanks in advance
Old 03-29-2009, 05:07 AM
SSedan64's Avatar
What parts of the 700's are grenading? Sun Shells? 3-4 clutches?
Old 03-30-2009, 12:56 AM
reply
Pretty much everything from the first cluster back. It is hard to tell I have even had part of a retainer come up through the floor board. The bottom end looks almost normal. They seem okay on the street and even on take off and burnouts.... its at about 75mph and 6200 rpm that it gets dicey. The last one locked up hard and i did about 4 donuts at 60 and ended up facing the wrong way in the other lane. (The State trooper who observed the rubber marks wasn't buying the stuck throttle excuse either ). I hear stories that people build them to take 600hp but no one can tell me who or how its done. I put a 4L60 with a shift box in that car but the $3500.00 price put a big hurting on my car stash. I stick them in cars with 383 strokers and they perform fine. It is almost like the 450-500 ft lbs of torque is punching through and spinning the guts out.. The clutches definitely are tweaked. The inners are rung out smooth like they were machined (If they aren't in a million shreds). I Picked up 4 350 short shafts and a glide for a 100 bucks today at the flea market so I have a temporary stay of execution.
Old 03-30-2009, 07:39 AM
LEE EYES's Avatar
Last journal entry: TBI experiment.
a 4l60e has the same internal components as the 700. most difference is valve body. there are a few things you can do to them to make the stronger. how deep are your pockets?
Old 03-30-2009, 08:04 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
This isn't a recommendation of these guys, I refer to them as a source of info. They may be fine, I just have no empirical knowledge of their products.
It’s explained HERE, as well as elsewhere on the site.
Old 03-30-2009, 12:00 PM
thanks/ figured it out
I called the people you linked me to and they were very helpful. Basically they told me that the 700r4 are fine unless you use them with high horsepower hi torque applications with a heavy car. The combination of the 450+ft lbs of torque, tubbed rear on a 4000lb+ car is pretty much the death knell for a 750r4. Looking back most of the cars i have used them in have been 30-40 model coupes or rat rods that are relatively lightweight and are not tubbed. For now it will be cheaper to keep getting the pglides and 350s even if they cost more for the core than I would like to pay. Guess I will keep buying lottery tickets... Then maybe I can afford Tremec
thanks for the help....BIG SCOTT
Old 03-30-2009, 12:13 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
LOL- I feel ya, man!
I keep eyeing my ca. 1968 Muncie M-20, trying to figure what I'll be able to get away with AFA torque. I/m figgerin on camming h ell out of my upcomming 406, it can't break if I don't have any torque down low, can it? lol
Old 11-20-2011, 07:17 PM
muncie
Just Grenaded my 66 muncie in the chevelle....The 550hp and 520ft lbs torque killed it at 145mph as I was getting close to the rev limiter right in the power band....Driveline loop PRICELESS....I cant Imagine Pole Vaulting over 100 mph..
Big block chevy into a 91 S-10?? 12second6 General Rodding Tech 11 04-28-2009 06:43 PM
Big Block 82 Pontiac Gran Prix william27103 Engine 3 03-30-2009 12:50 PM
Ford Big block 4 spd bellhousing bigblocktorino Transmission - Rearend 3 10-05-2006 03:56 AM
Small Block Vs. Big Block bfrett123 Engine 3 10-14-2004 05:27 PM
big block or small block ford? stangfiend Engine 3 12-10-2002 09:55 AM
