700r4 bracket -performer carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2011, 11:25 PM
Don Meyer's Avatar
I am looking for a tv cable bracket that is designed for a Edelbrock performer carb.
I want one that does not require replacing the trans spring. I have spent 12
hrs searching the web & all the brackets require replacing a internal trans spring or the bracket for a Edelbrock carb will not work on a performer series.
Help.........Don
Old 01-23-2011, 06:38 AM
SSedan64's Avatar
http://www.summitracing.com/parts/JET-700225/
http://www.summitracing.com/parts/SUM-700203/
This one will work if you're using a Carb spacer. http://www.summitracing.com/parts/BMM-64512/
Old 01-23-2011, 07:26 AM
SSedan64's Avatar
Don is your Eddy Carb a Q-Jet, Model 1901,1902,1903,1904 or a Square Bore style? If Q-Jet style the brackets above wont work.
Old 01-23-2011, 07:54 AM
Don Meyer's Avatar
I sure appreciate your help....... My carb is a Edelbrock 4106. The bracket
that is a extension of the metal carb spacer looks like it would mount the cable too high to be a straight shot in to the carb tv attaching point.
It looks like it mounts the cable above the spacer plate or am I looking at it wrong?
Don
Old 01-23-2011, 08:08 AM
SSedan64's Avatar
Yes the B&M bracket mounts the TV cable above the Plate in the Pic. The Up & down TV cable position isn't that critical. Front to back & side to side is more critical.
The Jet bracket mounts straight to the Carb base.
Many use the Holley, Eddy and Summit brand copies on the Eddy square bore Carbs with no problem combined with the Geometry corrector bracket also.
http://www.summitracing.com/search/D...?Ns=Rank%7cAsc
Old 01-23-2011, 08:36 AM
SSedan64's Avatar
This shows a Vortec Intake, Eddy Carb and Holley 20-95 Bracket.
http://i252.photobucket.com/albums/...uff/TVsetup.jpg
Just add a tab to the back end and run a 3" bolt down to the threaded boss behind the carb. Use a spacer between the boss and the bracket to hide the bolt.
The B&M Bracket in above post can be flipped so the TV is on the bottom.
Old 01-23-2011, 09:06 AM
Don Meyer's Avatar
Ok...it might work. I'll call them tomorrow. The image you referenced has been deleted.
Thanks Don
Old 01-24-2011, 04:45 AM
SSedan64's Avatar
Sorry about the Pic Don. I got the link from a search on MonteCarloSS.com Forum, you have to be a member to see much of anything on it.
There're quite a few Pics here>> http://www.google.com/images?hl=en&s...&aqi=&aql=&oq= may fine something that helps. Many of the Pics/links are from other forums so there should be Info as well.
Todd
Old 01-24-2011, 10:09 AM
Don Meyer's Avatar
Wow......thanks Tod. There is a lot of info there to read thru that should
help me in making a educated purchase.
Thanks...Don
Old 01-24-2011, 08:04 PM
Don Meyer's Avatar
my choice
I ended up ordering a Bow Tie kit......Don
Edelbrock performer and carter carb help ad forever Engine 5 01-20-2010 08:01 PM
700R4 TV cable bracket for 454? fastrehotrods Transmission - Rearend 3 08-03-2008 02:42 AM
Edlebrock Performer 750 carb SBCfan04 Engine 9 07-25-2008 01:50 PM
Performer RPM intake & carb Q MegaTherion Hotrodding Basics 1 09-14-2005 04:13 PM
Edlebrock Performer Series Carb trick66 Engine 4 03-02-2003 07:11 PM
