700r4 Bracketry questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2006, 08:08 AM
Fattys50
Last journal entry: new ride stance
Has anyone hooked up a 700r4 in there vehicle using stock bracketry out of the boneyard? I'm in the process of trying to figure this out on my dad's 38' chevy. So far, I've had to lengthen the bracket to get it to mount on the edlebrock eps intake manifold. I have tried some of the local parts stores for a throttle valve cable with no luck. I found a universal one at a tranny shop, but the order has not come in yet. I know that I can order cables and brackets from lokar, but we're tying to find another solution. We're hooking it to a 600cfm edelbrock carb. Is there any special bracketry I need to purchase for the cable mounting to the carb? Anybody with some advice would be greatly appreciated. Fats
Old 05-16-2006, 08:51 AM
302 Z28's Avatar
Both Edelbrock and Holley make specific bolt on brackets that give you the correct geometry for the 700R4. The Lokar unit is nice, and the Bowtie Overdrives unit is the gold standard, but both are overpriced and a simpler solution is availiable. I used the Holley bracket on my Street Avenger carb.
You ca however download the instructions from BowtieOverdrives that give you an idea of the geometry you need to replicate.
http://www.tvmadeez.com/article/index.php
Vince
Old 05-16-2006, 10:44 AM
Fattys50
Thanks
I appreciate the info. I'm hoping to get this figured out without catastrophic failure. Thanks Fats
700r4 cable questions bebopwally Transmission - Rearend 3 05-08-2006 04:54 PM
700R4 and 4L60E Questions transmandan Transmission - Rearend 2 04-25-2006 09:24 PM
700r4 rebuilding questions Anton Transmission - Rearend 1 06-07-2005 09:41 PM
700r4 wiring questions murrsue Transmission - Rearend 4 02-04-2005 10:09 PM
700r4 questions please help av8300zx Transmission - Rearend 2 06-09-2002 09:24 PM
