700R4 Build Up - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-30-2009, 11:11 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
yea i think that is a little crazy too. I am thinking i will be around 400ft/lb for my current build.
  #17 (permalink)
Old 10-30-2009, 11:13 PM
SSedan64's Avatar
If you look at CK's transmissions you'll notice the only one rated for 750ft/lbs has all the parts from the HI $$ Kit. I think he needs to reword his Rebuild kit descriptions. Those cheaper Rebuild Kits use the same clutches etc.. as the higher torque rated kits but they have the added Hard parts I was talking about for Transbrake an Hi HP/TQ ratings.
  #18 (permalink)
Old 10-30-2009, 11:20 PM
Listen and Learn
Wiki Edits: 7
yea i hear ya. So you think i would be best with this kit: HIGH PERFORMANCE OVERHAUL KIT B #7RK/HPB
  #19 (permalink)
Old 10-30-2009, 11:27 PM
SSedan64's Avatar
Yes, Before you order you should take your Pump apart and measure the pump pocket depth so you know what thickness Rotor & Slide you need. This clearance/tolerance is critical. Good Pump Info here, it's for a 2004R but, the 700R4 uses the same pump parts. >> http://www.ptsxtreme.com/faq/display_faq.asp?faq_id=4 about 3/4 way down the page.
  #20 (permalink)
Old 10-30-2009, 11:35 PM
Listen and Learn
Wiki Edits: 7
alright thanks a lot for the info. Please keep it coming. Also any reading info would be great.
  #21 (permalink)
Old 10-30-2009, 11:42 PM
SSedan64's Avatar
Lots of useful Info here
http://www.rowand.net/Shop/Tech/Auto...issionSwap.htm
http://purplesagetradingpost.com/sum...o/700R4p1.html
  #22 (permalink)
Old 10-30-2009, 11:50 PM
Listen and Learn
Wiki Edits: 7
alright thx SSedan for all the info. I love to read and love to learn so this should be a fun project. I have an 8' table all cleaned off and ready for me to start taking the trans apart and laying everything out as it came out.
  #23 (permalink)
Old 10-31-2009, 05:15 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Sorry, I just have to ask if you verified that you have a later model core or not.
Hate to see you throwing time and money into an inferior core.
  #24 (permalink)
Old 10-31-2009, 06:10 AM
Listen and Learn
Wiki Edits: 7
Yes pugsy its a 30 spline(counted it myself). Its from an 89 minivan. The only numbers that are readable on it are a couple numbers on the front pump 8654732. From the research i did it shows it is a 10vane pump for an 87-90 i believe.
  #25 (permalink)
Old 10-31-2009, 10:57 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Right on. Good to start with a decent core.
  #26 (permalink)
Old 10-31-2009, 05:31 PM
larrym's Avatar
Its a fun project satisfying when you getter done. I had mine in and out 4 times but its been great since.
  #27 (permalink)
Old 11-08-2009, 09:15 PM
Listen and Learn
Wiki Edits: 7
is transmissioncenter.net a place worth looking into for a rebuild kit? Sorry i keep digging this thread up but i have never done this before so want to get the most information and ideas i can. There was a couple different rebuild kits i was looking at. http://www.transmissioncenter.net/al...ower_packs.htm
  #28 (permalink)
Old 11-09-2009, 12:58 AM
JeffB's Avatar
700R4 build
Go to www.oregonperformancetransmission.com Great prices without middleman markup,I recommend these three part numbers,Rebuild kitTM-5100BHD,BEAST Sun Gear Shell NTP-51810,Shift kit: Superior/Fairbanks SUP-70015.For further advice talk to their Tech people, good folks to deal, with you may also want the 13 vane pump and a converter from them.
  #29 (permalink)
Old 11-10-2009, 06:52 AM
Listen and Learn
Wiki Edits: 7
so i was doing some reading on transmissioncenter.net which is PATCs site and they were saying that the 3.06 first gear kills your et compared to like a 200r4 gear? Is this worth replacing or not really worth it
  #30 (permalink)
Old 11-10-2009, 03:19 PM
larrym's Avatar
Do you have a decent 200R4 core to rebuild?
They are a little lighter from what i understand and 1-2 ratio's are closer together.
First Motor Build - a Mopar 451 Stroker? 71gtx Hotrodding Basics 10 05-01-2009 08:51 PM
700R4 into 79 Chevy Truck Torque454 Transmission - Rearend 7 03-08-2009 10:33 PM
A few Questions on a 700R4 swap. zbhover Transmission - Rearend 2 02-24-2009 05:13 PM
CMC '34 Coupe 1992 Build ffas23 Hotrodders' Lounge 11 12-04-2008 12:32 AM
Build a kit car Dutchman General Rodding Tech 9 09-23-2005 04:39 PM
