700r4 built pressure blew line, fixed now no d/od - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2009, 08:33 AM
Can anyone help. I just got this k5 jimmy with a new motor. trans. front and rear ends. sat for 5 years since all the new work. I know where it came from so I know the work was done. I serviced the truck and drove it about 50 miles total. Got in it one day drove it down my road about 1/2 mile. pulled out onto the main rd and got up to about 55 mph in 3rd gear. trans line blew. I didn't drive it at all with the line blown. I fixed the line and got the level back to where it should be. Now there is no 3rd or 4th. 1-2 shifts great. I let it sit over night and the next day I check the tv cable and that was fine. but after pulling on the tv about ten time I got in the truck and drove it to see if that maybe cured a stuck tv or not. not it's doesn't come out of 1st. I just dont think you lose gears overnight not running the thing.
Old 04-18-2009, 07:26 PM
Droped the pan and look what I found
I dropped the pan and there was 2 bolts and a clip that are ment to hold the line in place where it goes into the valve body. the other bolt went into the valve body itself. why would the come loose and could this affect the pressure that the trans is suppose to build in order to shift where it should?
Old 04-18-2009, 07:44 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
With parts flopping around loose in the pan , they may cause problems.
Are you talking about the oil transfer tube or other line loose?
Old 04-19-2009, 05:58 AM
It was the oil transfer tube. I was thinking that maybe it was alowing it to come free when the trans built pressure. The other bolt was just one of the valve body bolts. They were just laying there. no damage to the bolts at all. Could that just be a coincidence That those bolts were out and not neccasarily the problem? I'm going to drop the pan again and remove the valve body and clean it. Check the tv to make sure it's not just the plunger moving. This was a very strong, and very well shifting trans befor this line blew. I just dont get it. Must be a bad rebuild...
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 01:48 PM
Body Line Man586 Body - Exterior 6 08-20-2004 09:24 AM
Blew a brake line today oldschoolrods Suspension - Brakes - Steering 2 06-16-2004 09:30 PM
4L60/700R4 Pressure line juveteach Transmission - Rearend 4 09-15-2003 06:57 PM
Fuel Pressure DoubleVision Engine 18 05-31-2003 06:49 AM
