Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 burned low/reverse
Old 04-30-2011, 06:51 AM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
Originally Posted by stevetankl
Everything seems to be freshly machine. No cracks. Ok when I first crunk the car up. I noticed smoke coming from the dip stick too.
low reverse frictions are not moving when the vehicle is stopped, in park , etc... these frictions should not be smoking then.
if the clutch pack clearance is too thin , this will also burn these low - reverse frictions
