700r4 burned low/reverse
after 2 rebuilds, what can keep causing my low reverse clutches to burn up???
all seals are replaced, in the correct directions. clutches been soaked. what can it possibly be?
Everything seems to be freshly machine. No cracks. Ok when I first crunk the car up. I noticed smoke coming from the dip stick too.
low reverse frictions are not moving when the vehicle is stopped, in park , etc... these frictions should not be smoking then. if the clutch pack clearance is too thin , this will also burn these low - reverse frictions
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Ok. To retrace my steps...I was not sure how many gallons the tranny took so I added 6qts, crunk it up and ran it thru the gears. It creeped in r/d so I put it in park and checked the dip stick. Dry... so I added another 2qts, this time it jumped in r/d. Backed up and drove forward n shut it off. That's when I noticed the smoke coming from the dip stick tube. Could running it low be one of the problems?
since that trans and converter can hold 11 quarts of fluid, 6 quarts is not enough if the trans and converter were dry at a fresh rebuild
| 700r4 1988 2-4 band burned only | kag | Transmission - Rearend | 6 | 06-10-2011 07:06 AM |
| No reverse in 700r4 | randyb27 | Transmission - Rearend | 4 | 03-08-2009 10:33 PM |
| Low REVERSE BURNED AGAIN | Augusto | Transmission - Rearend | 2 | 07-08-2006 02:58 PM |
| 700r4 no reverse | bwood | Transmission - Rearend | 2 | 11-21-2004 06:26 PM |
| 700r4 no reverse or 2nd or 4th | slammedchevy86 | Transmission - Rearend | 1 | 03-30-2003 07:25 AM |
