700r4 change over - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2011, 07:55 PM
700r4 change over
I am getting a 700r4 for my 55 chevy the guy im getting the 700r4 from said it's none electric. and a freind said it needs lock up, can someone tell me if i need more. it's a 1989 trans. Bob
Old 03-19-2011, 08:59 PM
Last journal entry: Some More Roll Cage Fabrication
Your post is a little confusing. I believe that the guy you are buying it from is referring to this transmission as a non-electric 4l60. In the later years the 4l60(700r4) was changed over to a 4l60E which must be controlled by a computer. The 1989 is a lock up transmission that the lockup convertor can be controlled by a computer(factory in the later years) or with an aftermarket lockup kit such as B&M or TCI. It is even possible to fabricate/create your own torque convertor lock up kit. Please post some more information about your vehicle and exactly what you are trying to accomplish. Good Luck.
Old 03-20-2011, 07:35 AM
Crosley's Avatar
Wiki Edits: 1659
here is a wiki article that may help a little for converter lock up control on the 700r4. The article needs a little fine tuning
clik here for wiki
Removing a 2.8/700r4, Install V-8 with 700r4 1230firebird Transmission - Rearend 4 09-17-2007 05:17 PM
Rear end gear ratio change = spedo. cable gear change. help? turbo 350 sugar ray Transmission - Rearend 6 07-18-2007 11:32 AM
Covert maunal column change to auto column change devious Transmission - Rearend 2 06-04-2007 01:10 PM
What are the parts in a 700R4 2-3 TransGo shift kit 700R4 2-3 AngliaBob Transmission - Rearend 3 04-23-2005 11:25 PM
Won't change,wont' chang,won't change Samrupert Transmission - Rearend 6 01-11-2003 01:32 PM
