700r4 check balls
taking down my valve body in my 700...i had to tap it to get it lose. when it finally came lose 1 of the check balls cane out. i didnt get a chance to see where it came from. do anyone have some type of picture of where the check balls go? and how many there suppose to be?
The check ball locations differ slightly for different years.... mid 1987 was the change. Does your trans have the aux valve body at the rear of the valve body area or not?
At the Bonneville Salt Flats, first gear is known as 130 mph. |
no aux valve body. its an early 80's model. 30 spline
case check balls ;
where the bath shaped area has 1 check ball. Check the separator plate for two holes over the bath tub area partial case photo second photo of remainder check ball in case ; you may need valve body photo locations ?
thats great photos,
so all together theirs 6 check ball right? the valve bodt dont have any???
You may have missed my statement : Quote:
Witness marks on the separator plate are your friend when chasing down locations for check ball
early design valve body check ball locations.
Bath tub area in the yellow circle upper right side of photo; check the separator plate for dual (2) holes over the bath tub area.
| Kia fuel pump, again! | oldred | Electrical | 150 | 07-15-2010 08:32 PM |
| 700R4 Clutch Pack Air Check | mican99 | Transmission - Rearend | 2 | 04-19-2008 07:53 AM |
| Save the balls! Save the balls! (you know you want to) | ChevelleSS_LS6 | Hotrodders' Lounge | 2 | 04-21-2007 06:43 AM |
| identity theft and check fraud | 53LEDSLED | Hotrodders' Lounge | 5 | 07-19-2005 11:14 AM |
| 4x4 700R4 to 350 swap | Davesblazer87 | Transmission - Rearend | 4 | 12-22-2003 07:59 PM |
