700r4 checkball and low reverse checkball/capsule questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2012, 06:04 PM
Got an '87 model w/aux vb... I know that due to changes, things arent always put back the same as they were in these trannies. So my questions are based on that.... I apparently blew the checkball out of the capsule thats in the rear of the case when removing the low reverse piston. Is it needed or can it be left out? Secondly, anyone have a pic showing case and vb checkball locations. I've heard that some can be left out...
Old 09-11-2012, 10:53 AM
SSedan64's Avatar
3rd Post here may apply to the Capsule question:
4L60E build tips | TurboBuick.Com
Checkball locations:
700r4 check ball placement - Google Search
Old 09-11-2012, 12:00 PM
Thanks for the reply SS... I read the info on the first link but it seems like he's talking about the capsule for the servo on the side of the case. Instead of the one at the rear of the case for the low/reverse
I had also tried the google search for checkball locations but there were so many variances I thought I'd ask here. I saw an older post on here by Crosley from the ATSG manual that was for an '87 w/o the aux vb. But couldnt find one for the aux vb version like mine.
700r4 burned low/reverse stevetankl Transmission - Rearend 5 04-30-2011 07:45 PM
TH440-T4(ME9) 4T60 checkball locations zagyboy Transmission - Rearend 0 10-05-2009 02:06 AM
700R4 Low/Reverse Clutches Rough Transmission - Rearend 2 05-12-2005 05:34 PM
Please help I am in Checkball Hell dsmith1279 Transmission - Rearend 3 02-05-2005 01:26 PM
T-400 Sprag/Direct Clutch Checkball 68NovaSS Transmission - Rearend 3 04-27-2004 09:10 PM
