700R4 Clutch Pack Air Check - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2008, 08:13 PM
Rebuilding a 1991 700r4, (first time) I have assembled the input drum and did a 40 psi air test per the video, the 3-4 pack and the forward clutch appear to have no air loss, for the overrun seems to have a slight leak down, I can hear the piston engage and disengage. But I can hear a slight hissing. I have disassembled it and checked the seals a couple times. I canít seem to find any post pertaining to this.
Any suggestions/comments would be greatly appreciated, I have read the majority of post on this forum and believe I have learned a great deal from it.
Mike
Old 04-18-2008, 08:35 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Mike
normal air check of the o-r clutches.
You want the o-r clutches to come off and the forwards remain applied as you air check.
Old 04-19-2008, 07:53 AM
Thanks for the fast response, I will look into it more before I continue. Not in a big hurry. I not rebuilding out of desperation or trying to save a buck, it's in a spare vehicle and pull and disassemble as many time as necessary. Its been enjoyable this far, but the books/video seem to be lacking some.
Thanks again!
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
Clutch or transmission check? frankenvette Transmission - Rearend 4 09-24-2007 10:10 PM
Fresh air respirators 2stroketurbo Body - Exterior 26 02-15-2007 06:41 PM
1991 olds 88 coil pack check fumplet Engine 6 09-16-2006 08:12 AM
700r4 clutch diagram chevcamz28newbie Transmission - Rearend 0 08-04-2003 09:11 PM
