jws,
There is a white plastic sealing ring that goes in there. It plugs that port when you install the clutches. This part also keeps the input shaft aligned with the output shaft. Good Luck Scholman |
Thanks for the quick reply. So your saying this port seals with the teflon rings thru the stator and back to the valve body for the over run clutches? Just want to make sure I've got it right.
John |
normal stuff
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Thanks, Crosley. I'm hoping to get it right the first time. Everything is a lot heavier than I remember 28 years ago and crawling around under the truck hurts a lot more than I remember too.
John |
I understand.......
That's why I quit crawling around on the ground doing transmissions. ![]() I like this view better
Thanks for all the help gents, I was 'bout to pull what few hairs I left out.
Jake, that's right, rub it in. You've got a great set up there. I'm planning on a hoist in the new garage I'm building for the frame off on my '70 Chevelle if I live that long. The truck had a mind of it's own and gave up to early.Again thanks for the help. John |
| 1991 olds 88 coil pack check | fumplet | Engine | 6 | 09-16-2006 08:12 AM |
| 700r4 question | runn141 | Transmission - Rearend | 8 | 09-13-2006 12:36 PM |
| 700r4 forward clutch pack | Caesar_Mikey | Transmission - Rearend | 2 | 04-17-2005 12:51 PM |
| 700r4 clutch diagram | chevcamz28newbie | Transmission - Rearend | 0 | 08-04-2003 09:11 PM |
| bowtie sight, clutch pack and servo help | chevcamz28newbie | Transmission - Rearend | 1 | 07-30-2003 11:36 PM |
