Hotrodders Bulletin Board
#1
700R4 compatibility
I have a Chevy 89 S-10 700R4 Transmission and am trying to find out if I can put it into 95 Blazer 4.3 4WD. The two transmissions appear Identical, but what are the differences. Can I bolt a 2wd Trans into the 4wd transfer case?
#2
re: 700R4 compatibility
no. the 95 vehicle uses a 4L60E trans. Large round electrical plug on passenger side above the pan rail. The 89 trans will install in place of a 4L60E trans.... but the system will set trouble codes . Custom work will over come that problem a 2WD trans must have the 4x4 out put shaft installed
======== Save the earth , choke a tree .... save a squirrel |
Back to top |
Similar Threads for: "700R4 compatibility"
| 700r4 conversion questions | eric63chevy2 | Transmission - Rearend | 7 | 07-03-2007 01:37 PM |
| Putting a 1987 700R4 in my 1982 GMC 4x4... | indy_85stariones | Transmission - Rearend | 12 | 04-28-2007 02:04 PM |
| Rebuilding a 700R4 in 4x4 for towing... | indy_85stariones | Transmission - Rearend | 4 | 02-02-2007 01:26 PM |
| 700r4 and 4L60E | hotrod66_57 | Transmission - Rearend | 5 | 09-14-2005 03:34 AM |
| Need advice: 700R4 banging in 1st | 360Camaro | Transmission - Rearend | 11 | 11-20-2003 06:44 PM |
