Thanks! Thanks Top 5 Wiki Tech Article Editors! Thanks!
Updated June 18th, 2009
#1
Crosley
520 edits
#2
Crashfarmer
401 edits
#3
Alittle1
295 edits
#4
Techinspector1
173 edits
#5
Powerrodsmike
157 edits
Read and write hotrodding how-to articles on the Crankshaft Coalition Wiki. See 100+ articles, or read The 8-sentence guide.
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 09-17-2007, 07:23 PM
Chuck721 Chuck721 is offline
700R4 compatibility
I have a Chevy 89 S-10 700R4 Transmission and am trying to find out if I can put it into 95 Blazer 4.3 4WD. The two transmissions appear Identical, but what are the differences. Can I bolt a 2wd Trans into the 4wd transfer case?
Old 09-17-2007, 07:29 PM
Crosley's Avatar
Crosley Crosley is offline
Crosley's barnstarLast wiki edit: Troubleshooting torque converters
Wiki Edits: 550
no.
the 95 vehicle uses a 4L60E trans. Large round electrical plug on passenger side above the pan rail.
The 89 trans will install in place of a 4L60E trans.... but the system will set trouble codes . Custom work will over come that problem
a 2WD trans must have the 4x4 out put shaft installed
At the Bonneville Salt Flats... 130mph is known as First gear ...............
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "700R4 compatibility"
700r4 conversion questions eric63chevy2 Transmission - Rearend 7 07-03-2007 12:37 PM
Putting a 1987 700R4 in my 1982 GMC 4x4... indy_85stariones Transmission - Rearend 12 04-28-2007 01:04 PM
Rebuilding a 700R4 in 4x4 for towing... indy_85stariones Transmission - Rearend 4 02-02-2007 12:26 PM
700r4 and 4L60E hotrod66_57 Transmission - Rearend 5 09-14-2005 02:34 AM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 05:44 PM
