Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 Conversion
Old 02-08-2009, 11:52 AM
Fergusonic Fergusonic is offline
I am preparing for the same swap. In addition: The coolant lines are very close to the same position (hopefully the thread size will be the same). Driveshaft Yoke should be the same. Lockup Torque Convertor should mount to Flex Plate same as TH350 Convertor. Dipstick and tube are different. Rear mount is the same. If you are using a Lokar shifter; Lokar has an Adapter Kit that will convert the TH350 Shifter to the 700R4 so that detent, mounting, & rod will all work properly. It's not advertized but they have 'em for about $85.
