Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 conversion install problems
Old 11-26-2011, 11:19 AM
Steves68Camaro Steves68Camaro is offline
I dropped the pan again and pulled out the tvalve boost and found that the plunger for the reverse boost valve slipped inside the spring that came with the Fairbanks shift kit. Does anyone know if this would cause both the clacking noise and the reverse problem i described earlier? Any advice would be appreciated. Thanks
